Eastside Cruisers • View topic - Knocking noise from rocker cover?
It is currently Wed Jun 10, 2026 11:22 pm
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 22 posts ]  Go to page 1, 2, 3  Next
PostPosted: Sat Jul 07, 2012 8:54 pm
hi guys, took my LJ out for a spin today, got back home and at idle I noticed a knocking noise from engine, seems to be coming from rocker cover, towards the back near firewall and on passenger side. seems to go away when driving/revving engine. started it up again later and still a slight knocking noise but not as loud as before. any ideas?
PostPosted: Sat Jul 07, 2012 9:06 pm
Yeah go see the guy who took Your cash of you ? Eddie woods is the man you need to speak to
PostPosted: Sat Jul 07, 2012 9:18 pm
Probably a rocker has come lose but Leigh is right, take it back to Eddie to look at.
PostPosted: Sat Jul 07, 2012 10:03 pm
Definately sounds like a rocker has come loose
PostPosted: Sat Jul 07, 2012 10:21 pm
When the rocker cover comes off, check on the inside for a dint( I found a dint recently on my engine when one of the rockers came loose). And also get him to double check all of the other rocker bolts to ensure they are still all tight. Don't drive the car at high revs also when you drive it to eddys, as you don't want it to work itself completely loose etc.
One other thing I noticed when I had a loose rocker is that the car was seeming to backfire in the inlet manifold as the loose rocker wasnt opening the exhaust valve... Does your car seem to be missing or backfiring on idle or low revs?
PostPosted: Sat Jul 07, 2012 10:37 pm
ring eddy before you go driving it at all. you wouldnt want it to cause a spring to coil bind or something and hurt an engine
PostPosted: Sun Jul 08, 2012 12:18 am
thanks guys, will give Eddie a call monday, not missing or backfiring Beno, was still driving well but just an irregular knock at idle, hard to hear if its still does it when engine is revving :roll:
PostPosted: Sun Jul 08, 2012 6:28 pm
You have a kc rocker cover don't you? We had an issue with clearance against the rockers at one stage and had to use the die grinder for some clearance, its was around the rib area. Could be another possibility anyway!! As much as i love my rocker cover we have done nothing but modify it since day one!!
PostPosted: Sun Jul 08, 2012 7:13 pm
PostPosted: Sun Jul 08, 2012 10:59 pm
Just thinking, is it definitely coming from the rocker cover, or could it be from the clutch/flywheel?
