Eastside Cruisers • View topic - need help with cutting hole in bonnet
It is currently Wed Jun 10, 2026 10:20 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 23 posts ]  Go to page 1, 2, 3  Next
PostPosted: Tue May 24, 2011 7:57 pm
hey guys im after some help from someone who has experience in cutting holes in bonnets..i need one cut for the tonner but i have no skills so i need assistance.
If someone is up for it please let me know...willing to pay for the work..
Cheers.
Tony.
PostPosted: Tue May 24, 2011 8:25 pm
how big is the hole ??
PostPosted: Tue May 24, 2011 8:29 pm
this is how I did mine, but I need a jigsaw to do the job.
PostPosted: Tue May 24, 2011 8:41 pm
big enough to fit an 11" round k&n
PostPosted: Tue May 24, 2011 8:52 pm
tizzle when i done the vk i found u can use the bonnet locking hole and the bonnet lock as a guide or drill a hole ruffly where the center of the air cleaner is and put a mark on the top through the hole and measure it out that way easy as champ. use a jigsaw on slow with a new blade
PostPosted: Tue May 24, 2011 11:25 pm
when i did mine i made u carbie stud out of a bit of all thread long enough to mark the bonnet used the mark drilled a 1/8th hole through then used a airfilter hat as a template and used a grinder free hand with p;lanty of rags and masking tape not the best way but came up alright mines hidden by the scoop but so id go for a jigsaw with a good metal blade the more tpi the better
PostPosted: Tue May 24, 2011 11:37 pm
Yep did mine with a jigsaw too, and lots of masking tape down first.
Funny story there too - did mine late into the night, actually it was 1:00am - out in the driveway.... ahhh the beautiful sound of screeching metal in the still of the night.. AWESOME! :)
Pretty popular boy that night ;)
PostPosted: Tue May 24, 2011 11:47 pm
open your bonnet and run some string across from guard to guard crossing over your bolt hole put a bit of masking tape on your guards and mark with a pencil where it is then repeat on the scuttle and nose cone once marked close the bonnet put some masking tape where you think it might be then use the pencil marks to rerun the string and where it crosses is where your carby bolt will be pretty good chance it will be of to the left i know chevs are once you have your hole its up to you if you use a protractor or again some string by placing a bolt through the whole and some string at the length required say for instince if its a 11 inch air cleaner and you wanted a 12 inch hole (thats alowing half inch clearance)you would run 6 inchs of string once marked its your choice of cutting method i use a hack saw but its noisey and the edges still need finer finishing by hand.
PostPosted: Tue May 24, 2011 11:49 pm
i ment jig saw.
PostPosted: Tue May 24, 2011 11:51 pm
Why??? is my question.
Users browsing this forum: No registered users and 4 guests
