Eastside Cruisers • View topic - 9 inch sway bar
It is currently Wed Jun 10, 2026 10:52 am
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 18 posts ]  Go to page Previous  1, 2
 Post subject: Re: 9 inch sway bar
PostPosted: Sat Oct 16, 2010 4:51 pm
oldn64 you should put up some pics of your vl race car
PostPosted: Sat Oct 16, 2010 7:29 pm
PostPosted: Sat Oct 16, 2010 9:08 pm
Tim's approach sounds pretty good. It reminds me of something that the guys at Pedders told me many years ago..
I can't remember the exact figures, but it was basically something along these lines:
1. Choose your springs - this makes up approx 60% of your suspension setup
2. Now match with the correct shockers - this is approx 30%
3. Finish tweaking with sway bars if required - this is approx 10%
They were the key components. Obviously you need to have good bushes and stuff too.
Ryan - sounds like your setup is pretty decent with those components. The springs sound good. I assume you bought good quality shocks? Maybe lowering the car would help. Especially the rear if they are standard factory height springs? Just thinking out loud.
PostPosted: Sat Oct 16, 2010 9:16 pm
yeah the shocks are kybs i think they made a huge difference when i put them on gonna have a crack at fitting the sway bar
what thickness steel would be best for boxing the trailing arms
PostPosted: Fri Oct 22, 2010 6:40 am
PostPosted: Fri Oct 22, 2010 8:22 am
its got factory front bar it will be upsized was thinking about a front mount out
PostPosted: Fri Oct 22, 2010 10:19 pm
go a whiteline front mount swaybar kit as they work really well, we run them on all of our torries and i found it worked better than the old larger than stock rear mount swaybar even tho they were the same thickness, plus it gives you heaps more room for larger pipes! :D
PostPosted: Fri Oct 22, 2010 10:49 pm
Hey Shannon, are the Whiteline front-mount front bars just a simple "bolt-in" fit, or is there any welding for brackets or anything required?
I'm very keen to fit a front-mount bar on LXCHEV. Got any photos of yours?
