| Eastside Cruisers http://www.eastsidecruisers.com/forums/ |
| For Sale: Borg Warner diff suits LC/LJ Torana http://www.eastsidecruisers.com/forums/viewtopic.php?f=6&t=659 |
Page 1 of 1 |
| Author: | LHoon [ Sat Apr 30, 2011 4:56 pm ] |
| Post subject: | For Sale: Borg Warner diff suits LC/LJ Torana |
For Sale: Borg Warner diff to suit LC/LJ Torana Complete - ready to bolt in All work professionally done by Keysborough Diffs Mini spool 28 spline axles 3.23 ratio Disc brakes Slotted rotors Torana stud pattern It is standard R31 Skyline length, so that means its about 20mm longer than std Torana length either side. This is not a problem with the right offset wheels. I used ordinary 14" or 15" steel volvo rims without any problems. I also have some custom widened (15x8") volvo rims, which I can sell too if interested. I spent the money to get this diff built properly and it has new street-friendly gear ratio. $1200ono Ph 0421 112 348 (Scott) |
| Author: | mr5000 [ Sat Apr 30, 2011 5:35 pm ] |
| Post subject: | Re: For Sale: Borg Warner diff suits LC/LJ Torana |
does it come with brand new wheel studs does any one no how much power the borgies can take a mate of mine has just dropped a 383 into a lj i think he might have trouble with the 10 bolt he has in it |
| Author: | LHoon [ Sat Apr 30, 2011 5:53 pm ] |
Yep, comes with new wheel studs. Borg warner diffs are pretty strong. There are 9 second VL commodores still still running BW diffs. I also measured the axle diameter once, and they're the same size as a 9 inch axle. |
| Author: | LXSS5L [ Sat Apr 30, 2011 9:16 pm ] |
Show us some photos of the LC with the new diff and wheels fitted Scott. |
| Author: | LHoon [ Sun May 01, 2011 4:08 pm ] |
I still have a bit of work to do! To fit the new tyres I need to do some mini-tubbing. But I've bolted the new diff if for now. But as you can see, it sits like a 4WD because the tyres hit on the inner guard. |
| Author: | Dan71 [ Mon Apr 08, 2013 12:16 am ] |
Hi mate, Just doing similar mod to my Lc, can u fit those wheels without changing standard shock and spring mounts? Thanks |
| Page 1 of 1 | All times are UTC + 10 hours [ DST ] |
| Powered by phpBB® Forum Software © phpBB Group https://www.phpbb.com/ |
