Eastside Cruisers • View topic - Engine doesn't turn off - back feed through ignition switch?
It is currently Wed Jun 10, 2026 6:46 pm
Forum locked This topic is locked, you cannot edit posts or make further replies.  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Sun May 20, 2012 12:07 pm
if you can actually get an older style davies craig one you would be better off. the new ones are solid state which is great but they will only come on when they reach like 190 degress which is normally not much good for a hotty on a hot day. the early style ones you can make the fans come on from stone cold if you want. as for the magna switches etc, some cars they work great in others they dont, main reason is they are designed to maintain a temperature, we have put a few in limo's and they work great on a cooler day but get a 40 degree day and the temp begins to creep a bit.
PostPosted: Sun May 20, 2012 5:49 pm
I k ow your a auto elec James but I disagree about not being able to set the below 190 these could be adjusted to run where ever you set them.
PostPosted: Sun May 20, 2012 11:47 pm
the new ones cant be made to come on really early.. the old ones you can set to come on at stone cold if you want. they had a proper set of contacts inside them. ive got the new style on my patrol and cant make it come on under almost 1/2 which is about 90 deg c.
PostPosted: Mon May 21, 2012 1:29 am
Fair enough then I'll have to take another look at Mitch's set up
PostPosted: Wed May 23, 2012 9:38 am
brett
i will have a scrounge and post info
i fitted to quite a few cars and seems to always work
cheap and one wire.
they screw into manifold next to thermostat
ISO
PostPosted: Wed May 30, 2012 10:30 pm
Hi Brett,
Sorry it took soo long
thermo fan switch is a TFS139 buy at repce from a mitsubishi magna 1985-1991
M16 x 1.5mm thread
single wire
turns on at 85 deg C and off at 80 deg C
mount near the thermostat on engine
either in a existing bung or drill and tap a new hole
run a 170 thermostat
should run all day without switching anything at around 180 deg F
can help with wiring diagram if you need or want
cheers
iso
PostPosted: Thu May 31, 2012 11:55 pm
Awesome, cheers for the detailed info Iso.. as soon as I get a free arvo, I'm going to commit some time to sort this out.
Thanks again!
